pullin motor with trans and speedmasters >
Old 04-08-2006 | 04:36 PM
Default pullin motor with trans and speedmasters
Pulling the motor tomorrow , Can I pull the motor and trans with out removing the drive by walking everything forward ?Trans is new to me. Just pull the two as one assembly correct ?
drewwilliams is offline
Old 04-08-2006 | 05:16 PM
Scarab3DMC's Avatar
Default Re: pullin motor with trans and speedmasters
I did it that way x2...
Scarab3DMC is offline
Old 04-08-2006 | 05:19 PM
Well yeah, you probably can if you have six or more inches to move the engine/tranny forward before you tilt and/or lift it out. But what would be the point, since you will want to align everything after the engines are reinstalled prior to bolting up the outdrives? --- Jer
jpclear is offline
Old 04-10-2006 | 03:00 AM
Reed Jensen's Avatar
Yes you can remove the engine and transmission without removing the outdrive , provided there is enough room to slide the engine and trans forward almost 1 foot to disengage the driveshaft. But.... here is the bad news... you will most definately have to remove the outdrive to put it back together, because you cannot refit the driveshaft to the transmission coupling if you have hands any bigger than a small monkey...
Reed Jensen is offline
Old 04-10-2006 | 08:32 AM
44MTI's Avatar
I have pulled mine this way several times, also reinstalled the motor and tranny together without touching the outdrive. Maybe I just got lucky, but I will be reinstalling them this week like this.
44MTI is offline
Old 04-10-2006 | 04:12 PM
birdog's Avatar
Plug in or Drive line style ?.....I know it doesnt matter with driveline style
birdog is offline
Old 04-15-2006 | 07:48 PM
How long will they be in this time.
Enough 4 Play is offline
RMPRam
Cigarette
4
07-12-2008 07:09 PM
Wally
6
06-27-2006 08:22 AM
mtgbiker
9
02-11-2005 03:19 AM
Shane
10-13-2002 08:54 AM
hystat
2
05-27-2002 05:35 PM
