Saginaw to brazil valve conversion >
Old 04-09-2006 | 10:00 PM
Hot Boat's Avatar
Team Dysfunctional
Default Saginaw to brazil valve conversion
I have a 1988 transom assembly with the old style steering valve. There is play in the vale and I want to replace it.
Can I install one of the newer style valves in its place?? Is it a direct replacement????
If it aint broke .... I can break it....
Hot Boat is offline
Old 04-10-2006 | 06:01 AM
Pwrbt33's Avatar
Default Re: Saginaw to brazil valve conversion
The new valve will bolt right up. The only problem will be the hoses nees to be replaced. The Saginaw valve has flare fittings on the end of the hoses and the Brazilian valve has O-ring fittings on the end. Also make sure you have room on the top of the cylinder. The Saginaw valve the hoses come into the front of it and the Brazilian hoses come into the top.
Good Luck, let us know how it goes.
John S.
Pwrbt33 is offline
Old 04-10-2006 | 06:23 AM
Mbam's Avatar
Offshoreonly Advertiser
We can sell you the new cylinder for $100
Mbam is offline
slik22
Scarab
3
04-04-2008 11:31 PM
Rookie
6
06-20-2007 07:01 AM
Magic Medicine
16
05-22-2006 02:26 PM
MadMat
0
04-06-2006 05:50 PM
Hot Boat
3
05-26-2005 08:02 AM
