Procharger M1sc on 7.4MPI Help !! >
Old 04-10-2006 | 06:24 PM
snake plissken's Avatar
Unhappy Procharger M1sc on 7.4MPI Help !!
I have my boat at a Mechanic and hes stuck on a few issues this is his first install of a procharger on a boat.He has the install manual from procharger.
ok first does the oil cooler go back on ?? if so where is it relocated?
I have a set of dana headers and looks like they are going to have to manufacture a bracket.
fuel preasure regulator install as well ? any help would be great [email protected]
snake plissken is offline
Old 04-10-2006 | 07:36 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: Procharger M1sc on 7.4MPI Help !!
Will ask pops. Never liked the procharger but we got one worken real good. Will ask how.
TeamSaris is offline
Old 04-10-2006 | 08:01 PM
Pat McPherson's Avatar
Yes! you need the oil cooler; you may even consider buying a lager one.
Yes! you will need an adjustable fuel pressure regulator to raise the fuel pressure. There are kits to modify the stock regulator. Call AZ Speed, Precision EFI, or Tyler Crockett...
Patrick
Pat McPherson is offline
Old 04-10-2006 | 08:03 PM
One other thing, go easy on the timing. The combo of the Vortec heads and cast piston in that engine are a receipt for a melt down...
Happy Boating!
Patrick
Old 04-11-2006 | 07:16 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
The regulator to use should have came with the kit.. & yes you need an oil cooler.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 04-11-2006 | 08:32 AM
Hi Jamie is it relocated? the oil cooler?
Old 04-11-2006 | 03:58 PM
I dont believe The oil cooler should have to be moved.. & yes you do need it. The OIL FILTER does get relocated. If it was a new kit then it should have came with the relocation hardware... If you bought a used kit somewhere & need parts for it I can get them for you..
Jamie / Lakeside
Old 04-11-2006 | 04:43 PM
TeamSaris's Avatar
Driver-441
Racer
Call us for help tell them johnny sent you, 518-644-3080
Old 04-11-2006 | 11:59 PM
Thank you guys !! picked up the boat and im taking it to a place who has done these before the guy seemed to know his stuff. will keep you posted thanks once again
screamin_69
Wanted
12
07-09-2008 11:33 PM
baronbob
1
08-15-2005 08:11 PM
heatwave3
13
07-06-2004 03:45 PM
baronbob
4
07-05-2004 08:04 PM
baronbob
6
06-10-2004 01:53 PM
