Hatch lift and dead batts? >
Old 04-10-2006 | 09:03 PM
Default Hatch lift and dead batts?
I am wondering what some of you do. If your batteries go dead on you or if you have an electrical problem, how do you open the hatch. I'm currently installing a new lift mtr and wiring it up. I thought about an extra terminal mounted under the seat leading to the mtr or a quick disconnect cable attached to the pin on the hatch bracket.
Surely someone has this problem solved.
tomcei is offline
Old 04-10-2006 | 09:08 PM
Panther's Avatar
Frank's Marine Service
Default Re: Hatch lift and dead batts?
I made a pull pin attached to a SS cable that you can access by taking the 6 screws that hold the air vent on the side of the boat. Pull the vent off, pull the cable and you're in.
Panther is offline
Old 04-10-2006 | 09:25 PM
I can turn my switches off and have a set of cables that are hooked to the battery that powers the hatch and a pull pin just in case.
fstboater is offline
A buddy of mine has a electric hatch and his allows the cylinder to open and lift away, allowing you to muscle it open. I take it not all lifts are that way?
happy hours is offline
Old 04-10-2006 | 09:41 PM
Ted G's Avatar
I feed my panel with a jumper box and open it normally. This wont work if the ram goes bad so I am thinking of adding a cable/pin deal also.
www.cbpba.com
Ted G is offline
Old 04-10-2006 | 09:43 PM
My pull pin has a button that needs to be depressed to relax the small ball bearings( qty2) in the end so it will pull out.
Panther, is yours like that?
I guess I can look for a different style pull pin that might be more accomodating (sp) Otherwise, I need to rig up somethig to push the button and pull the pin at the same time
tomcei is offline
Old 04-10-2006 | 10:51 PM
bring a new charged 12 volt battery into the cabin or wherever your access is to the back of the switch to raise the hatch. Use allegator clips to the back of the switch or board to supply fresh power to up switch.
ActiveFun is offline
Old 04-11-2006 | 04:59 AM
Iggy's Avatar
My Formula engine hatch has a separate aluminum frame that's hinged at the rear. I can lift the hatch manually or power it up. Nice feature if the battery dies.
Iggy is offline
Old 04-11-2006 | 05:43 AM
mwdill's Avatar
i can pull a piece of the back bench off and reach thru a designed hole to the pin and pull it out and lift manually.
mwdill is offline
Old 04-11-2006 | 06:14 AM
GOODT's Avatar
back feed with jump pack though lighter/aux socket
or if you own a fountain you dont have that problem, they have jump cable hook up under the seat
GOODT is offline
