MSD Distributor rust >
Old 04-10-2006 | 10:26 PM
H2oRigger's Avatar
Default MSD Distributor rust
Can I still use this Distributor. Is there replacement parts for the ones that are rusty.Its a MSD 8560. Don't no how the water made it in. Thanks Phil
H2oRigger is offline
Old 04-11-2006 | 05:03 AM
cig1988's Avatar
Default Re: MSD Distributor rust
Send it back to MSD in El Paso & they'll freshin it up for you.
If you do send it out, check out thier turn around time. Gets busy this time of year. I would also send them the MSD box to check that out as well. Ideally if you can afford to keep a spare box it would be a good idea. Seems they always go out when you need it the most.
cig1988 is offline
Old 04-11-2006 | 05:38 AM
mwdill's Avatar
mine did the same thing.
mwdill is offline
Old 04-11-2006 | 06:39 AM
RLW
I sent mine for a refresh three years ago. The cost was $75.00. You will receive (basically) a new distributor, cap included.
Chances are, it will not be the same one you send them.
I had a small prick punch on the base ring to help facilitate installation and get me close to base timing. The distributor I received did not have the prick punch.
It is a good deal.
RLW is offline
Old 04-11-2006 | 06:55 AM
They all do that.Take it apart,brush off all the rust,spray paint the rotor with a can of Merc. etching primer,this will last several seasons.
roarkace is offline
Old 04-11-2006 | 07:18 AM
CIG3's Avatar
You can buy all the parts from Summit and do it your self if MSD's turn around is too long. CHange the distributor gear while your at it.
CIG3 is offline
Old 04-11-2006 | 08:01 AM
Took mine apart yesterday and it was trashed. No onder the boat was hard to start and wouldnt idle ..
drewwilliams is offline
Old 04-12-2006 | 12:06 PM
H2oRigger's Avatar
Thanks Cig3. Summit has it all. Just one question anyone ever replace the reluctor in there msd billet PN-8560. I've change gears and rotors but never the reluctor. Thanks Phil
Old 04-12-2006 | 12:44 PM
Mr Gadgets's Avatar
Charter Member #601
I did.. and the replacement was a bit different than the one I took off. I think there was an extra slot or something, but they just press off, not a big deal. I just cant remember what I found different.. I think I had to cut a slot in the new one.. have to revisit it..
Dick
Mr Gadgets is offline
Old 04-12-2006 | 12:55 PM
H2oRigger's Avatar
Thanks Dick. You said it was short a slot? I have the link to summit with the reluctor showing. Does this one have the slot you were talking about. thanks again.
Phil
http://store.summitracing.com/largei...t=MSD-PRD10071
