anybody have a diagram of drive trim connections for ssm #3s >
Old 04-15-2006 | 08:08 PM
ratman's Avatar
Default anybody have a diagram of drive trim connections for ssm #3s
a friend of mine disconnected my trim ram hyd lines amd didn't make where they go, and i dont know what goes where now, i have 1979 cig with the original rams and square bottom trim pumps. thx for any help. rm
ratman is offline
Old 04-15-2006 | 09:15 PM
Lofty's Avatar
Default Re: anybody have a diagram of drive trim connections for ssm #3s
Are you trying to figure out which hydraulic line is "up" and which is "down"?
Lofty is offline
Old 04-16-2006 | 12:39 AM
ratman's Avatar
yes, which is up and down on the pump and the rams
ratman is offline
Old 04-16-2006 | 07:13 AM
The lines on the distribution block could have been reversed over the years. So the best way involves trial and error. The pump has a hi and low pressure side, they are not interchangable.
Energize the blue side, this is the trim up, high pressure circuit. hook the high pressure hose up and see if the drive goes up. If not, switch it.
Green is the low pressure, down circuit.
Gary
rdoactive is offline
Old 04-16-2006 | 01:19 PM
Lofty's Avatar
The hi-press or up lines are normally the front lines on the block. If you look in the bilge, most riggers will put one or two wire ties on the up lines where they go throught the transom. If you have to you can trace the lines from the pumps. The hi-press. fittings are marked.
Lofty is offline
Old 04-16-2006 | 01:20 PM
Lofty's Avatar
Sorry, I didn't answer both questions. The rear fitting on the ram is the up fitting.
Lofty is offline
Old 04-16-2006 | 03:07 PM
ratman's Avatar
lofty thx for your help, rm
ratman is offline
Old 04-24-2006 | 07:03 PM
ratman's Avatar
rdoactive, the blue green check is what got me sorted out, someone had swapped the lines at the block under the drive. thx, rm
ratman is offline
Old 04-25-2006 | 09:08 AM
Gald it helped. On old boats, it seems to be a 50:50 chance if they're right.
BTW, if you're hooking up trim tabs, it's the opposite.
Blue, high pressure for down. Green, low pressure for up.
Gary
gotime34
06-15-2006 09:34 PM
baja27
09-07-2005 08:42 AM
ratman
4
06-23-2005 04:24 PM
blown formula
16
11-27-2002 04:35 PM
