Lifting Strakes
Old 04-16-2006 | 07:59 PM
Default Lifting Strakes
I'm currently replacing the stringer system in my 22 Donzi Classic. My plan is to fill the hollow strakes from the inside with fiberglass. Hopfully this will stiffen up the hull a little more. Does anybody have an opinion as to whether this would be a good thing or bad thing?
IHTFP is offline
Old 04-17-2006 | 05:07 AM
David's Avatar
Default Re: Lifting Strakes
Use 1/4 round (trim) and fill with putty made from resin and some filler material (cabosil or similar), then glass over. It will stiffen up the hull.
David is offline
Old 04-18-2006 | 04:16 PM
glassdave's Avatar
Neno the mind boggler
filling them may stiffen it up a bit not sure if it would be enough to notice though. if you really want to do somthing to tighten up the bottom put a core in it.
08 OPA High Points Champion
glassdave is offline
Old 04-18-2006 | 04:20 PM
Dave,
That may be an option. Would coring it with Coosa Bluewater 26 be a good option?
IHTFP is offline
Old 04-18-2006 | 04:59 PM
glassdave's Avatar
probably better off with a Baltek or Dyvincyl. Coosa is better for bulkheads and stringers.
Old 04-18-2006 | 05:12 PM
What would be the best thickness of coring?
IHTFP is offline
Old 04-18-2006 | 07:40 PM
glassdave's Avatar
1/2" or maybe 3/4" depends on how much room you have and stiffness you need to add. i would think 1/2 should be enough.
Old 04-18-2006 | 09:47 PM
Dave,
That sounds like a good plan. Would coring also be good for stiffening up the hull sides in addition to the hull bottom? Would I go all the way up to the rubrail?
IHTFP is offline
taxguy
Detailing, Painting, & Fiberglass
5
09-06-2006 03:06 PM
Cattitude
3
07-29-2006 08:23 AM
DRTOBE
5
04-08-2003 12:22 PM
26sonic
01-20-2003 10:22 AM
