Ignition Timing >
Ignition Timing
Ignition Timing
Old 04-17-2006 | 09:51 PM
Cool Ignition Timing
What should the stock Merc thunderbolt ignition timing be set at on a 1989 330hp 7.4L. Looking for the most advance without detonation for more hp. Should this be set at Idle with base timing or is it better to rev up the engine and set the timing while it has full advance?
mtocrs1 is offline
Old 04-17-2006 | 10:17 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Ignition Timing
With the stock Merc ignition, you are limited as to what you can do. I would set the timing at full advance to 35*. Let the base end up where it wants to.
Vinny P is offline
Old 04-18-2006 | 01:17 AM
I doubt you will gain a thing by advancing it. Stock is 32* at full advance. Do a water test with a GPS and bump it to 34-35*.
Griff is offline
Old 04-18-2006 | 03:57 AM
fbh-velocity's Avatar
I allready done that, bin there. NO increase at all. Stay at 32* and be on the safe side of detonation.
fbh-velocity is offline
Old 04-18-2006 | 04:37 AM
GOODT's Avatar
best wat to go, if you go much more then 34 total you will need to increase octane
GOODT is offline
Old 04-18-2006 | 11:27 AM
Cool Re: Ignition Timing
At what RPM should the timing be at full advance?
mtocrs1 is offline
Old 04-18-2006 | 12:35 PM
If your module is Thunderbolt 24 * Designation V8-24
3750 RPM
kcvega
8
07-15-2010 01:39 AM
prostockcat
3
06-14-2008 12:37 PM
ak
7
02-23-2008 10:12 AM
vendetta
11
02-23-2006 05:37 PM
THRILLSEEKER
8
02-25-2003 09:07 PM
