Anyone changed impellors -496 >
Old 04-18-2006 | 12:22 PM
Blewbyyou's Avatar
Question Anyone changed impellors -496
I wanted to find out if anyone here has changed the water impellors on a 496 HO? Dealer wants $500 to put the housing kits in 2 motors. Is this high or is it really that much work? Any info or help would be appreciated.
Blewbyyou is offline
Old 04-18-2006 | 04:58 PM
GOODT's Avatar
Default Re: Anyone changed impellors -496
Thats about right very expencive housing
GOODT is offline
Old 04-18-2006 | 05:55 PM
Dave M's Avatar
Veteran: Navy
Why do the housings need to be replaced? I thought the 496's had a brass housing.
Dave M is offline
Old 04-19-2006 | 07:50 AM
Sydwayz's Avatar
Forum Regulator
It is a pain in the ass to R&R the impellors on the 496s, but not hard to do by oneself. The brass housings should not be bad, and they cost around $300-$400 for each housing (they are brass), so I doubt they are replacing the housings.
I could see them charging 2 hours per motor plus impellors and seals plus shop fees.
I have twin 496HOs, and I have done mine a couple times.
Sydwayz is offline
Old 04-19-2006 | 10:28 AM
Blewbyyou's Avatar
Thaks guys! The motors are pretty tight...29 Outlaw. He said he would have to remove the rear bench to get to the starboard side. He checked them today and said that he didn't think they were bad yet. How often should you replace these?
Old 04-19-2006 | 10:31 AM
BajaRunner's Avatar
I did mine on a 29 on my head. it can be done, but a pain in the a$$.
BajaRunner is offline
Old 04-19-2006 | 11:52 AM
fountain27ho496's Avatar
365 Hours and never changed it, If it isnt broke.....or am I nuts? JC
fountain27ho496 is offline
Old 04-19-2006 | 11:58 AM
29KILROY's Avatar
your nuts....
29KILROY is offline
Old 04-19-2006 | 12:11 PM
BajaRunner's Avatar
your nuts, definately a maintanence item. your on borrowed time.
Old 04-19-2006 | 12:29 PM
25 hors la loi's Avatar
Your are not alone ...... here 546 hrs ...and never got a trouble.....but i will definitely exchange it this spring !!!!!!
25 hors la loi is offline
