Mounting swim platform
Bought a swim platform for my Topgun. I am going to thru bolt it. Some will be below waterline and dont want any water intrusion.
Do I use resin to seal holes?
Do I use 5200?
Do I use both?
Do I use 5200?
Do I use both?
The above would certainly work but it's overkill. If you caulk it correctly inside, outside and on the bolt with 5200 you shouldn't have a problem.
Check your placement several times, and check the inside before you drill. It might seem obvious but plenty of people get hurrying and drill right into a wire harness, or a hose, or dead into the middle of a stringer.
