Deisel ??
Old 04-23-2006 | 09:36 AM
TeamSaris's Avatar
Driver-441
Racer
Default Deisel ??
I no deisel's dont start up well in the cold weather so is there anything to kind of help them out? Like the engine block heater?? But that wont help the glow plugs, right?
TeamSaris is offline
Old 04-23-2006 | 10:27 AM
OldSchool's Avatar
Default Re: Deisel ??
I before E except after C
OldSchool is offline
Old 04-23-2006 | 11:12 AM
"I" before "E' except after after "C" and except in "Budweiser"
Alot of diesels have "block heaters" which one can plug in (AC) during the winter- most auto supply stores sell these. I worked for an ambulance service and they worked well!
Fast Shafts is offline
Old 04-23-2006 | 11:55 AM
JCPERF's Avatar
What a weisel
JCPERF is offline
Old 04-23-2006 | 12:16 PM
masher44's Avatar
What a weinie
masher44 is offline
Old 04-23-2006 | 01:50 PM
TeamSaris's Avatar
Driver-441
Racer
oops
Old 04-23-2006 | 01:59 PM
every diesel Ive ever seen comes with a block heater.......the one in mine will melt snow off the hood if theres no wind
pullmytrigger is offline
Old 04-23-2006 | 08:32 PM
There is magnetic oil pan heaters...junkie quick ...then there is the one where you pop out freeze plug and put it in there....good one....and there is one that you put in your heater line....like a little pump with heating element....some do not have the pump and rely on heat gravity circulation..these are not great and must be set up to make sure of gravity up flow or else you will boil the element.......then you can put whatever you use on a timer to go on at 4 am!
Byrdman is offline
purnell
4
12-07-2006 10:11 AM
DMAX
13
07-10-2006 07:59 AM
Buddy OO
22
04-17-2006 07:01 AM
Wild
11-01-2005 06:35 PM
dyno
23
03-26-2004 12:19 PM
