Motorized Navigation Pole Light?? >
Old 04-23-2006 | 09:03 PM
Default Motorized Navigation Pole Light??
Has anyone ever seen a motorized 360 degree navigation pole light....similar to a power antenna?
enticer is offline
Old 04-23-2006 | 09:12 PM
woogie's Avatar
Default Re: Motorized Navigation Pole Light??
Eddie Marine about 150 bucks. Try Trick
woogie is offline
Old 04-23-2006 | 09:16 PM
Ted G's Avatar
Unless you are real set on one, you might want a regular one. The internal connections on those don't seem to hold up well, makes the light blink a lot and sometimes just not light Always an adventure
www.cbpba.com
Ted G is offline
Old 04-23-2006 | 09:22 PM
I'm seeing them more often these days on boats I survey. I believe Cablemaster is the manufacturer.
Edward R. Cozzi is offline
Old 04-23-2006 | 09:40 PM
paradigm shift's Avatar
Innovative lighting makes one. New ones are LED and I have had no trouble with mine. If you turn the switch on then off then back on it will signal SOS. I really like mine and I also have a stern light mounted on the transome so it is more of an anchor light. I got mne from Eddie Marine.
http://www.eddiemarine.com/Cart/deta...&CategoryID=56
paradigm shift is offline
Old 04-24-2006 | 07:14 AM
scottc's Avatar
I have one I'll let go for $50.00. Never installed. Also have a bow nav light that is motorized.
scottc is offline
Old 04-24-2006 | 07:16 AM
scottc's Avatar
Here ya go
Attached Thumbnails Motorized Navigation Pole Light??-ebaystuff-022-large-.jpg   Motorized Navigation Pole Light??-ebaystuff-023-large-.jpg   Motorized Navigation Pole Light??-ebaystuff-024-large-.jpg
scottc is offline
Old 04-24-2006 | 07:26 AM
GLH's Avatar
GLH
Originally Posted by insptech
...internal connections on those don't seem to hold up well, makes the light blink a lot and sometimes just not light...
I have never had a problem with the one that came with my boat.
Also there is a setting that will make the light blink SOS in morse, maybe you are mistaking that setting for loose connections.
I use my boat in fresh water also, so it might be a salt water enviroment issue if there are people having problems with those.
GLH is offline
Old 04-24-2006 | 08:53 AM
scottc,
You have a PM.
Baja Pete
baja pete is offline
Old 04-24-2006 | 10:20 AM
ratman's Avatar
kill 2 birds with one stone! get a motorized stripper pole and put a light on top
ratman is offline
