Latham steering mounting info >
Old 04-24-2006 | 01:20 PM
pachangalpina's Avatar
Default Latham steering mounting info
I am in the process of installing a used Latham steering set on twin Bravos and need to know where to mount the rams. I contacted Latham and they said they would have to mail me a template because they could not fax it. That was almost 2 weeks ago and I am ready to move with this project. Anybody know how to place the rams in reference to the transom assembly? I guess the main thing that I need is the dimension from the crankshaft centerline to the mounting bracket or from the transom assembly to the mounting bracket.
Thanks, Todd
pachangalpina is offline
Old 04-24-2006 | 02:46 PM
Zanie's Avatar
Default Re: Latham steering mounting info
I believe I have it written down at home.
What is the length of stroke of your steering cylinders?
Dan
Zanie is offline
Old 04-24-2006 | 04:55 PM
8" stroke. 16" eye to eye (closed) 24" eye to eye (extended)
Thanks, Todd
Old 04-26-2006 | 06:27 PM
Zanie's Avatar
OK,
So when I called them last summer, they told me with 8 inch stroke cylinders, the horizontal distance from the centerline of the drive (crankshaft, ect), to the center of the mounting bracket for the cylinder should be 15-3/8 inches. They didn't give me a tolerance on that measurement or tell me if the if the height should be even with the cap when it's trimmed neutral or up where I normally run. I'm still a week and a half from drilling my transom for my cylinders, so I'm a little unsure.
Does that help?
I hope so!
Dan
Zanie is offline
Old 04-26-2006 | 08:08 PM
32storm's Avatar
The installation templet for Latham drives with Bravos( 15 JUN 95 print)has a dimension of 15 3/8" from centerline of drive to the centerline of the cylinder bracker that mounts to the transom. this templet is for Latham Bravo only with "Latham cylinders with 11/16" rods and rod ends, or Latham cylinders with 7/8" rods and intergral std. CL. joints."
Centerline of bracket in vertical plane is level with centerline of drive.
32storm is offline
Old 04-26-2006 | 08:15 PM
Keep after it Todd
tomcei is offline
Old 04-27-2006 | 07:59 AM
Thanks guys!!!
boatguy94
3
01-12-2021 07:13 AM
t500hps
Wanted
0
07-22-2008 08:54 PM
24degrees
6
02-16-2006 12:39 AM
seanhammond101
1
10-14-2003 07:14 PM
SinkorSwim
2
07-29-2003 12:52 PM
