Dyno numbers >
Dyno numbers
Dyno numbers
Old 04-26-2006 | 07:58 AM
Default Dyno numbers
Got the engine on the dyno yesterday and did three pulls.The best i got was 3300 rpm 600 Clp-ft and 377 CHp
5200 rpm 494 Clp-ft and 500 CHp
The engine is a 502 bored out to 540 . need some input on the numbers before i do #2 engine.The engines will be going into a cigarette bullet.Trying to get the boat in the low to mid 70 range
riski bidness is offline
Old 04-26-2006 | 01:44 PM
KAAMA's Avatar
Default Re: Dyno numbers
If your peak torque is 600lbs @3300rpm then I would say it is a bit on the low end. Is the intake manifold you're running a single plane or dual plane intake? and whose brand?
Also, do you happen to know what the cam specs are? (duration @ .050")
Any additional info you can give concerning the engine would be helpful.
KAAMA is offline
Old 04-26-2006 | 02:52 PM
Kaama i will get with the engine builder tonight and let you know.t5hanks for the reply
Old 04-26-2006 | 04:15 PM
Need parts to know. It sounds low. Here is a dyno sheet of a 540 inch with GM Iron rectangle port heads, and a merlin single plane with dominator carb.
TxHawk is offline
stevesxm
43
12-22-2005 10:01 AM
375stinger
9
11-13-2004 09:20 PM
puder
09-03-2002 09:11 PM
26scarab
3
05-21-2002 10:39 PM
