Help with valve spring parts Please! >
Old 05-04-2006 | 02:09 PM
Hello,
I hav e Gen V 502 with about 500 hours on it. The engine is untouched GM Marine, except for Gil exhaust. I am going to purchase the Edelbrock Aluminum RPM Marine oval port heads that come with the valves and seals. My dilema is what other parts should I order to finish off the installation. I was thinking Comp springs and Harland Sharpe roller rockers. I am loooking for advice on what Valve springs, retainers, locks etc. I should use. Please include exact part numbers and only proven solutions. Since I will be going from Rectangular to oval port heads I will also need a new dual plane intake manifold, Edelbrock RPM or Wold dual plane? Any advise would be greatly appreciated.
Thank You
Bartholomew is offline
Old 05-04-2006 | 03:09 PM
Default Re: Help with valve spring parts Please!
Edelbrock RPM
I just installed a set of Ovals two weeks ago.
I had the machine shop order the springs. I wanted the height setup correctly without using any shims. Going off memory I think I used COMP CAMS 926 dual springs. We ended up adding no shims or any modifications.
The valve guides did have to be honed because they were to tight.
Its cool when you pick them up with one hand
1BIGJIM is offline
Old 05-04-2006 | 08:42 PM
KAAMA's Avatar
Bartho,
"rmbuilder" Bob Madara of Marine Kinetics in N.Y. would be a good guy to consult and can get you everything you need for your valve train. He has helped engineer marine combinations for many on here. Bob's number is (585) 654-8583
KAAMA is offline
Old 05-07-2006 | 01:39 PM
Wink Re: Help with valve spring parts Please!
For that stock block/cam setup, use the Comp 26120 beehive ovate springs and Comp recommended retainers and locks for these springs. Your cam, roller lifters and rockers will be happy, reliable, heat free and long lived.
Ray @ Raylar
Raylar is offline
Old 05-07-2006 | 07:46 PM
Bart,
I have seen so much variation in cylider heads lately that I simply will not order valve springs, retainers etc until I have the heads on the bench with the valves that are being used so that I can measure installed height. Period ! Get the heads and valves, have your machine sho check the dimensions, then order the rest of the parts. I know this is a pain, but its the only correct way to do it. By the way, Edelbrock and GM do not seem to like using a spring locator seat on thier aluminum heads. I dont like to do it that way and try to find a spring that will work with the .050" thick locators. Less wear and tear on the heads in the long run.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 05-07-2006 | 07:51 PM
Elite Marine's Avatar
Bartholomew,
Where are you located? Find a reputable shop in your area. If anywhere near IL call Bill at Ateco Engine and Dyno Shop.
www.atecoengines.com
He has been at this for 30+ years and he and Bob Madara work together often. Between the two of them, they'll get you moving again!! They sure helped me!
Kirk
Elite Marine is offline
Old 05-08-2006 | 11:12 AM
Hello,
I will get the heads with valves in my possession to determine install hieght then go from there. I think I am liking the Isky springs. I would like to order the Roller rockers with the heads, so has anyone used a roller rocker with the aluminum Edelbrocks that they are pleased with? I am located in Phoenix Arizona, does anyone have a cylinder head shop recommendation in my area?
Thank You,
traviss
40
09-27-2009 08:15 AM
boatguy94
1
03-11-2008 09:57 PM
MOP
1
06-11-2006 10:57 AM
ctadams21
12
05-20-2005 11:51 AM
shawn
01-19-2004 02:55 PM
