painting bottom?
If it was me , I'd put the boat on two 8' long 4X4's (or something else appropriate) standing on cinder blocks. That way you can roll it on one side at a time . Seems that unless the boat is hanging by lifting eyes you will only be able to do one side at a time .
You can block it on a side, paint one side to the keel then block it on it's other side and blend it along the keel. Or drain everything and roll the boat over.
I aasume your spraying the Awlcraft and you want a nice shiney finish and your not talking about antifouling "bottom paint"
How big is this boat and what facilities do you have access to? I have always had the bow lifted on a stand( which was moved to paint and quickly placed back under with 1/2inch off the stand and the rear was chocked as far back as possible (stop painting a foot away from the stands) and wasn't painted until the next day when the chocks were moved forward so it could be blended. The AwlCraft is good for that.
BluWaterNC
Detailing, Painting, & Fiberglass
2
02-24-2008 10:07 PM
BluWaterNC
Do It Yourself, Boating on a Budget
5
01-29-2008 01:32 PM
