Flat Top Pistons >
Flat Top Pistons
Flat Top Pistons
Old 05-05-2006 | 03:53 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
Default Flat Top Pistons
Gen 6, HP500.
I'm way out of my league here but what are the feelings on flat top pistons? We have discovered in tearing down my motors, that one of my motors was rebuilt last year using FT pistons. I'm trying to match the second motor and FT's are not what we were planning on using. We were going more toward the stock Merc pistons, but these were a bit harder to find. (so I'm being told) I'm not against them, I just don't want the ease of securing FT's being the reason we go this direction.
Also, I'm hearing that the FT's might decrease my compression??? Feedback would be great & remember I'm a novice at this.
Blue by You is offline
Old 05-06-2006 | 04:36 AM
Iggy's Avatar
Default Re: Flat Top Pistons
It all depnds on the chamber size and shape. You get the wrong pistons for the head and you'll wind up with a bad case of detonation, or worse.
There's nothig wrong with a flat-top. GM used them for years in their engines.
Some 383 SBC's run dished pistons with a small chamber head. The small chamber allows for better quench.
Iggy is offline
Old 05-06-2006 | 06:06 AM
Linster's Avatar
Off the Radar
A Flat top piston will have a -3cc eyebrow cut in the top for the intake valve to clear. A 502 piston has the same but the little dome on top brings it up to +1cc. Going to flat tops, all being equal, the compression goes down -4cc. If for say the 502 was to a perfect spec, 8.75 CR, a flat top will be 8.52CR, a loss of 1/4 point compression.
Bore x Bore x Stroke x .7854 = Cylinder displacement
Cylinder displacement x 8 = Engine size
Compression Ratio = ( Cylinder Displacement + Chamber Volume ) / Chamber Volume
Linster is offline
Old 05-06-2006 | 11:37 AM
Rebel_Heart's Avatar
This past week I spoke with Jim V. as he was working on my heads. He said that he usually uses a domed piston, but that he would work around the flat top pistons that my engine builder had used.
Rebel_Heart is offline
TINO160
9
08-17-2009 07:12 AM
Ted
7
06-26-2005 11:44 PM
hpy540
3
02-01-2005 10:06 PM
Scarab28
11
05-18-2004 09:17 AM
mcraymond3
Cigarette
16
05-08-2004 10:23 PM
