trailer needs new brake system
Old 05-05-2006 | 09:40 PM
duunoit's Avatar
Default trailer needs new brake system
I have a South Florida trailer for my 28 Pantera. Believe it or not, it doesn't have brakes on it. The trailer is triple axle and rated for 10.5k lbs. I was looking at http://shop.easternmarine.com/
and am plannig on getting the TITAN/DICO #5237003 (it's a 10k actuator) and 4 of the Tie Down 5256153 disc brake assemblies (and putting them on the front two axles). It seems like most of the triple axle trailers I've seen only have brakes on two of the three. It looks like I can buy all of the parts (actuator, assemblies and a tubing kit) for about $900 shipped. Anybody have other suggestions?
duunoit is offline
Old 05-05-2006 | 10:20 PM
scottc's Avatar
Default Re: trailer needs new brake system
You might want to consider the ele over hydrolic actuator. Much more control and you will not have to change the tounge.
scottc is offline
Old 05-06-2006 | 07:16 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I'd go with Kodiak disk brakes over Tie-Down and electric over hydraulic is the way to go.
Check with www.championtrailerparts.com and www.kodiaktrailer.com
Sydwayz is offline
Old 05-06-2006 | 07:24 AM
Ditto on the Kodiak brakes, I have had a set of the all stainless (I boat in salt water) and have loved them for the 2+ yrs I have owned them. Brakes pads are standard cheap as dirt , front wheel drive GM pads you can buy anywhere...nice touch.
happy hours is offline
Old 05-06-2006 | 08:53 AM
duunoit's Avatar
What do you guys think about this:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4628795663
duunoit is offline
Old 05-06-2006 | 01:26 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That is a great kit. I have never seen it packaged like that. HOWEVER, you want SS Calipers and Nickel Cadmium Rotors (or SS Rotors if you want to drop the coin).
I don't believe that eBay kit is made up of those materials. Kodiak offers them several different ways. Even in fresh water, you want the above combination I mentioned.
Sydwayz is offline
Old 05-07-2006 | 01:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I have the Kodiak disc on my Eagle. The pads have rubbed groves into the hubs. I've been informed to grind the pad backing plate to clear.
US1 Fountain is offline
duksrule
4
07-03-2006 12:40 AM
duksrule
2
06-29-2006 02:37 PM
duksrule
05-26-2006 09:20 AM
dockrocker
18
06-27-2005 12:03 AM
eyezlee
11
06-13-2002 11:27 AM
