Radio Guru's..... >
Radio Guru's.....
Radio Guru's.....
Old 05-07-2006 | 04:13 PM
Default Radio Guru's.....
Last year I installed A Sirius Sportster at my helm.....can't get rid of the a tiny high pitch interference sound.....everyone tells me to check the ground....I am a Radio install novice....where do I start?? By the way the the unit is not hard wired, I plug it into the cigarette lighter.....
Here's Johnny is offline
Old 05-07-2006 | 06:41 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Radio Guru's.....
Hey John,
I cant help you with your problem. Dont know chit about stereos. BUT, I called your cell, got your voice mail. Give me a call. I wanted to see what you were doing this coming weekend. I went out on my first run of the year today.
I am ready to go.
Vinny
Vinny P is offline
Old 05-07-2006 | 07:55 PM
Elite Marine's Avatar
Most installers will seperate the Pos from the Ground to avoid radio interference. Check your wiring. Also, most guys will tell you to run your ground to the terminal of your battery to avoid other interference.
Elite Marine is offline
Old 05-08-2006 | 07:23 AM
Install this.
http://www.crutchfield.com/S-ADDJhsT...lter&i=003S15A
NightHawk is offline
Old 05-10-2006 | 04:36 AM
Looks like I will give that a try Nighthawk.........Thanks
Old 05-10-2006 | 08:22 AM
Shore Thing's Avatar
My old truck used to have the same problem and i installed a filter like Nighthawk showed. Worked like a charm.
Shore Thing is offline
Old 05-10-2006 | 02:02 PM
Airpacker's Avatar
you can accomplish the same thing with a 3 dollar capacitor. ground the case, hook wire to positive feed to radio. Thats all a "noise filter" is but in a box.
Airpacker is offline
Old 05-10-2006 | 04:41 PM
The noise filter also contains a series inductor.
Old 05-11-2006 | 11:35 PM
hunster's Avatar
Originally Posted by NightHawk
Dont waste your money on that band aid.
hunster is offline
Old 05-12-2006 | 06:53 AM
Hold on chief. I'm not Mr. engine guru but I am Mr. electronics guru. While that device is a simple thing it is a perfectly legitimate solution to noise and interference, whatever the source, on a DC supply line. It is a series inductor and parallel capacitor that form a low-pass network and it is very effective when installed properly. It's only 12 bucks for Christs sake!. What's the problem?
speedreeder
9
01-31-2008 09:16 PM
MacGyver
12-28-2006 04:09 PM
FASTERDAMITT
10-11-2005 07:48 PM
