F-350 Headlights
Old 05-09-2006 | 07:22 PM
RedDog382's Avatar
Default F-350 Headlights
Changed out the '01 to '04 for $120/side:
Attached Thumbnails F-350 Headlights-f-350-001.jpg   F-350 Headlights-f-350-002.jpg   F-350 Headlights-f-350-004.jpg
RedDog382 is offline
Old 05-09-2006 | 07:24 PM
RedDog382's Avatar
Default Re: F-350 Headlights
Closer:
Attached Thumbnails F-350 Headlights-f-350-006.jpg   F-350 Headlights-f-350-005.jpg   F-350 Headlights-f-350-003.jpg
Old 05-09-2006 | 07:29 PM
eyezlee's Avatar
Looks much cleaner. I need to do that to my '03. Where'd you get the lights? Dealer?
eyezlee is offline
Old 05-09-2006 | 07:37 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I bought Projector Beam APC lights for my 2000 Ford along with clear turn and corner lamps and a 2005 style grill; all on ebay. The headlights have separate high and low beams, and come with everything included, including integrated fog lights. I have mine all hooked up along with my own relay to make low beams and high beams on at the same time with my own discretion.
RedDog, yours looks great. I highly recommend this guy from eBay for the grill upgrade:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33645
Sydwayz is offline
Old 05-09-2006 | 07:55 PM
DirtyMoney's Avatar
03 is the same as the 04's
DirtyMoney is offline
Old 05-09-2006 | 08:10 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Just about all the parts are available on eBay. You will want to get 2005 and newer parts as 2004 to 2005 was the biggest change. The 2005 bumpers are a little different too, and if you buy the grill from the eBay guy I noted, he takes a factory Ford grill and trims it to properly fit a 1999-2004 bumper.
Sydwayz is offline
Old 05-09-2006 | 08:39 PM
Dock Holiday's Avatar
Charter Member #34
I put the same ones on my wife's 2001 Excursion and they look great. However they have been on it for at least two years now and are starting to get scratched real bad. It seems like the lens is not as tough as the factory units.
My 2002 F-350 has the newer style lights and it has more miles and they look better. FYI for what it is worth.
Guess I will have to change her's out again.
Dock Holiday is offline
Old 05-09-2006 | 08:42 PM
BZ's Avatar
BZ
was a direct replacement no mods????
now all you need is an Excursion grill
BZ is offline
Old 05-09-2006 | 10:50 PM
RedDog382's Avatar
These are aftermarket pieces that I picked up at Chuck Nagy's body shop in Deerfield, Michigan. He can usually get them in overnight from a local warehouse. The headlight assemblies are from "Eagle Eyes", supposed to be the same manufacturer as O.E.M. Visteon from Ford Dealer are $160 each for headlight assembly only.
Turn signal/side marker is another aftermarket manufacturer (Depo), but they look identical to the O.E.M.
These take about 5 minutes to change out both headlight and turn signal without any modifications.
Change was made to the backing plate and headlight assembly in '05 and they are not interchangable.
Old 05-09-2006 | 11:04 PM
buck183's Avatar
Idiot!!!
Buck
buck183 is offline
