wtf happened? tried a 28p bravo one >
Old 05-11-2006 | 10:52 AM
BajaRunner's Avatar
Default wtf happened? tried a 28p bravo one
I am running a set of bravo one's 26p's labbed by throttle up with no cup. turning them at 5600 rpms.
Tried bone stock 28's and could only turn 4600 rpms. slip numbers were better with the stock, but why only 4600???
2000 36' baja outlaw, twin hp500's
BajaRunner is offline
Old 05-11-2006 | 11:20 AM
Panther's Avatar
Frank's Marine Service
Default Re: wtf happened? tried a 28p bravo one
I had a similiar problem with the 28's. Maybe they're a larger diameter?
I was testing 28's and could only turn 4600, tried 24's went to 5700, then 26's to 5300.
Panther is offline
Old 05-11-2006 | 05:07 PM
FASTERDAMITT's Avatar
Interesting!
FASTERDAMITT is offline
Old 05-15-2006 | 02:52 PM
BajaRunner's Avatar
ttt
Old 05-16-2006 | 09:22 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: wtf happened? tried a 28p bravo one
Each application is different. 28 B1's have their own personality too.
Your current props may be able to be adjusted furhter to improve your performance. Where do you need to get to? And where did you start at?
[email protected]
bbladesprops is offline
Old 05-16-2006 | 10:24 PM
Gordo's Avatar
Charter Member #94
You're turning 26p's at 5600 rpm?
Are your HP500's stock? If so, the rev limiter should have held you at 5350rpm.
Abby-someone
Gordo is offline
Old 05-17-2006 | 08:34 AM
Panther's Avatar
What's your feeling on cutting the diffuser rings off?
Panther is offline
FormulaOne
Insurance and Finance
22
07-27-2007 06:32 PM
blaniac
Active Thunder
50
06-23-2007 11:04 AM
2 Trick Rick
OPA/The Jersey Boyz
22
03-21-2007 06:38 PM
ratman
11-18-2005 03:12 AM
