2001 Ford F250 Powerstroke
Old 05-12-2006 | 03:46 PM
Default 2001 Ford F250 Powerstroke
Any issues to be aware of in this particular model?
BGIII is offline
Old 05-12-2006 | 04:26 PM
birdog's Avatar
Default Re: 2001 Ford F250 Powerstroke
I have an 00....It's been a great truck.....crank trigger at 80k..warranty..Water pump at 90k..$325 for the part...
birdog is offline
Old 05-12-2006 | 04:58 PM
articfriends's Avatar
In 98/99 ford went to a improved version of the e4od transmission in the automatic trucks called a 4r100. In late 2000 and all the 2001's ford went to a failure prone mechanical diode sprag in 2nd gear. The part failed so much that ford got rid of it and when you rebuild them they have to be retrofitted with earlier style 2nd drum,sprag and a different spline 2nd clutch. Fords aren't as popular around here as gm's but I have repaired at least 15 of them in past 3 years. If trans hasn't been done yet there is a chanch you will experience failure after 80,000 plus miles. Budget in the possibility of a 1800-2500$ trans job. A good customer of mine bought a 2001 w/120,000 miles for a second work truck for his concrete company. He has spent over 8000$ between the trans,front end work,turbo,injector pump and other repairs in 60,000 miles/2 years. He said no more fords but he does haul 8000-13000 lbs and has yo/yo's driving his trucks. I have heard the same from a few of the other customers that I have done transmissions for,Smitty
articfriends is offline
Old 05-12-2006 | 06:48 PM
Registered User
Ford uses the International 444 motor and calls it the Powerstroke 7.3. Probably the most widely produced, most succesful diesel engine ever produced. The only reason they changed was emissions laws.
Chris Sunkin is offline
Old 05-13-2006 | 09:01 AM
offthefront's Avatar
Smitty... great input ..... I am looking at a 99 PS Ford ....50K ..So if I read your post right a 1999 is a good buy ? .... m
offthefront is offline
Old 05-14-2006 | 05:05 PM
My understanding is the motors are the same (99 vs 01) but the bad sprag design makes the 01 transmission MORE failure prone. Ive repaired more 01 transmissions than 99's,Smitty
Old 05-14-2006 | 05:35 PM
Thanks guys.
BGIII is offline
Old 05-14-2006 | 05:44 PM
7.3 cant beet , i had a 2005 f 350 6.0 ...junk sold it and lost my butt , but happy camper now , i have a 2001 its the best truck have 70.000 miles on it , not broke in yet , had a 99 f 350 put 250.000 miles on that pulled 13.000 pounds around all day long , i have 4 .....7.3 they are the cats ass ,
elroy521 is offline
Old 05-14-2006 | 06:02 PM
Thumbs up Re: 2001 Ford F250 Powerstroke
I have a 2002 7.3 ps, and love it, never a problem towing anything, would not own anything else!
orlando is offline
tony manzella
11
07-01-2008 05:11 PM
CMG
4
05-26-2007 10:25 AM
frequentflyer
58
10-11-2005 07:56 AM
Sydwayz
7
06-22-2005 11:46 AM
