HP estimate?? >
HP estimate??
HP estimate??
Old 05-13-2006 | 09:39 AM
Default HP estimate??
My motor now:
Chevy Bowtie Block
502 Marine HP Heads (Fresh springs and conical valves)
Roller Rockers BB 1.7 "PRO SERIES"
Edlebrock Airgap RPM intake manifold
502/502 cam from crate motor
SRP lightweight flat tops
Dimple Rods
Holly 850 Double Pumper
Anyone want to make a HP estimate???
Longrange4u is offline
Old 05-13-2006 | 01:12 PM
vandeano's Avatar
Default Re: HP estimate??
Longrange4u,
I guess I'll look for the answer to my HP question here Have you ran it yet. I even noticed that engine came with exhaust...not a bad find by the looks of it.
vandeano is offline
Old 05-14-2006 | 05:11 PM
articfriends's Avatar
I'd guess 550 hp,Smitty
articfriends is offline
Old 05-14-2006 | 05:51 PM
dyno's Avatar
Charter Member #655
Smittys close 525-550.... I'll bet the 850 is fat, try a 800.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 05-14-2006 | 08:07 PM
Dyno... you think that the 850 will be fat? You think I need to jet it down or different carb?
Old 05-15-2006 | 12:50 PM
This was in a previous post on my 496. I am running a 750 Demon Double Pumper
This is based on 496 inches at 5400rpm max
Total airflow requirements:
658.75 cfm
49.49 pounds of air.
3.36 pounds of fuel
Fuel Supply requirements:
0.56 gallons per minute for 14.7 A/F ratio.
38.66 gallons per hour for 12.8 A/F ratio.
146.33 liters per hour for 12.8 A/F ratio.
Here is the link http://www.smokemup.com/auto_math/airflow.php
the plus 15% is for marine applications based on what I have seen in this forum
1BIGJIM is offline
SHARKEY-IMAGES
General Racing Discussion
1
04-21-2006 06:44 AM
racinbird
Baja
7
02-21-2004 11:38 AM
HyperBaja
Baja
30
12-27-2002 01:43 PM
283CHECK
06-06-2002 12:56 PM
dreamer
06-03-2002 07:18 PM
