steering hub removal >
Old 05-15-2006 | 04:45 PM
Shore Thing's Avatar
Default steering hub removal
I purchased a platinum hub and steering wheel to replace the factory hub and white wheel on my velocity. I took the old wheel off, and then removed the locknut from the center of the old hub. I thought the hub would just pull right off. Well, it won't budge and I'm afraid of forcing it too much. I did stick a wrench in there and try to pry it with no luck. Am I doing this wrong? Is there a trick to removing hubs? I thought maybe some corrosion had bonded it together. Any help would be greatly appreciated. Thanks!
R,
Lance
Shore Thing is offline
Old 05-15-2006 | 04:48 PM
yesrej's Avatar
Default Re: steering hub removal
i changed the hub in my old boat. it was a 1990 four winns liberator. hub wouldnt budge. so i torched it. after a little while it came off. not saying its a good way to do it but it worked.
yesrej is offline
Old 05-15-2006 | 04:55 PM
haulinvols's Avatar
www.Bajaboatowners.com
The shaft that the hub bolts to is tapered, when the nut is tightened is presses the hub onto the shaft. To remove it you will need a steering hub puller. I got one for 14 bucks at the local auto parts store when I did mine.
haulinvols is offline
Old 05-15-2006 | 05:04 PM
Is something like this what you used?
http://www.autozone.com/servlet/UiBr...EGRN%7C%7Etrue
Old 05-15-2006 | 05:23 PM
haulinvols's Avatar
That one might work. I used this one.
http://www.partsamerica.com/ProductD...r=T73904158694
None of the bolts that came with the kit fit my hub, but I had some that worked.
Old 05-15-2006 | 08:53 PM
Fast Forward's Avatar
I just ran into the same issue. I sprayed a little WD40 on it (carefully), placed the nut back on and with a few light taps with a hammer it came right off. Mine is a 97 so just under 10 years of being on. I did have a puller and that was the next step if this failed.
Fast Forward is offline
Old 05-15-2006 | 11:10 PM
ratman's Avatar
i left the nut hand tight and pulled on the wheel while i hit the nut and it popped right off
ratman is offline
Old 05-16-2006 | 07:35 AM
Thanks guys, i'll give it a shot.
GO4BROKE
Sonic
12
12-05-2007 10:43 PM
375stinger
0
12-24-2006 08:42 PM
375stinger
Checkmate
0
03-08-2006 03:32 PM
gripit
1
01-11-2005 11:44 AM
gripit
Cigarette
0
01-10-2005 08:49 AM
