P5X vs. Hering 5 blade rpm's & performance? >
Old 05-20-2006 | 08:50 AM
Harper220's Avatar
Default P5X vs. Hering 5 blade rpm's & performance?
I'm currently running 29p P5X's on my 28 Daytona @ 5000-5100 rpm's. I have a free chance to try a set of 31p Hering 5 blades that came with my fathers new Donzi 38 ZR. Would they work on my Daytona and what rpm difference might I experience? Right now my hole shot is a little slippery with the p5x's and a high x dimension. How about hole shot with the Herings and overall performance differences? Any opinions would be appreciated...
Harper220 is offline
Old 05-20-2006 | 06:32 PM
louietherigger's Avatar
Racer
Default Re: P5X vs. Hering 5 blade rpm's & performance?
It sounds like they might be too big, but there available and nothin beats trying them out, check with Throttle Up they know how to calculate slip and all that stuff.
louietherigger is offline
Old 05-23-2006 | 11:46 AM
throttleup's Avatar
The HEring props are 2 inches taller so your RPM should drop but Hering propellers are available in custom diameters so this will effect the outcome as well. But I envision that you will loose a fiar amount of RPM. Addtionally the P5-X props will induce some bow lift and the Hering props are stern lifting props.
Julie
throttleup is offline
Donzi38ZXXX
Prop Talk
6
06-12-2007 08:25 AM
Harper220
Prop Talk
6
03-07-2006 10:57 AM
Popeyes
12-13-2005 10:07 PM
baja27
01-11-2005 10:17 AM
RUNNIN A FEVER
Fountain
1
01-30-2003 05:59 PM
