97 502/415 Gaskets >
97 502/415 Gaskets
97 502/415 Gaskets
Old 05-21-2006 | 07:43 PM
502SCS's Avatar
Default 97 502/415 Gaskets
I have a blown head gasket so I am taking my 97 502/415 MPI down to the block. I decided to replace the exhaust manifolds also while at it. 2 things to work out now that it is apart. It only has 160 hrs on it. so I guess I should leave the stock cam and timing chain alone... Or should I ?? Other question, does anyone have Felpro gasket numbers for the merc 27-811546 head gasket and 27-805403 intake gasket ?
502SCS is offline
Old 05-21-2006 | 09:25 PM
Default Re: 97 502/415 Gaskets
The Fel-Pro marine gasket number for a 502 gen. 5,6 is #17049. Summiit or Jegs sell's it for about $53 each.
Jrock is offline
Old 05-21-2006 | 09:48 PM
502SCS's Avatar
Just went to summit and this came up for Gen 6 502
FPP-17048 also
502SCS is offline
Old 05-22-2006 | 01:47 PM
duunoit's Avatar
If you're going to go with FelPro you ought to be looking at the head set (17207). It has 2 of the 17048 head gaskets, intake manifold gaskets, exhaust manifold gaskets and valve stem seals. Summit has it (FPP-17207) for $141.69
duunoit is offline
Old 05-22-2006 | 04:19 PM
502SCS's Avatar
Great ! Thats what I need .. So that is the best quality head, intake, exhaust and valve seals for that marine motor...Thanks for the info
502SCS is offline
noyzee
Donzi
21
10-03-2008 11:59 AM
DENNYB
05-28-2008 03:33 PM
Fast Shafts
7
08-08-2006 11:06 AM
502SCS
05-21-2006 07:42 PM
502SCS
19
02-13-2005 10:25 AM
