Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
3M 4200 or 5200????? for swim deck? >
Old 05-22-2006 | 08:56 PM
G Man's Avatar
Default 3M 4200 or 5200????? for swim deck?
Mounting an aluminum swim deck on my boat. Will through bolt it of course but what should I use 3M 4200 or 5200 adheasive / sealer?????
G Man is offline
Old 05-22-2006 | 09:06 PM
Elite Marine's Avatar
Default Re: 3M 4200 or 5200????? for swim deck?
I don't recommend 5200. You may need to replace or repair that platform sometime!
Elite Marine is offline
Old 05-24-2006 | 02:31 PM
I agree. 5200 is for PERMANENT installations ( like through-hulls and trim tabs) and bonding floors and such.
Gmoney52 is offline
Old 05-24-2006 | 02:51 PM
racer-x6's Avatar
If you use 5200 you don't need bolts
racer-x6 is offline
Old 05-24-2006 | 09:21 PM
Racer
Thats funny
Old 05-24-2006 | 09:49 PM
Audiofn's Avatar
Charter Member #232
I put made the mistake of my life when I put my transom assemblies on with 5200 It is going to SUCK to get them off.
Put your best foot forward!
Audiofn is offline
Old 05-25-2006 | 09:12 AM
offthefront's Avatar
on the 5200 or 4200 .. can you use acetone or ? to clean the joints when you first install something ?
offthefront is offline
Old 05-25-2006 | 12:18 PM
racer-x6's Avatar
Acetone is fine for cleanig surface prior to using 5200
One time we had a boat come in the shop for a steering cable that required removing the motor.This was a 200 Merc, I removed all the bolts and the motor was still hanging on with the 5200. After working for an hour or so it came off with a big chunk of gel-coat not good!
racer-x6 is offline
mcprodesign
Fountain
4
01-30-2008 02:28 PM
ls1nova
Powerplay
3
10-24-2007 01:14 PM
G Man
3
05-22-2006 11:13 PM
F223LS
04-03-2002 07:42 AM
