What's the diff between standard mirage vs mirage plus >
Old 05-23-2006 | 05:07 PM
I everyone
I don't know what's the difference and that will help me if someone knows
My scarab 29 2000 with 2 fresh 350 mpi 300hp each with Bravo 1 HP, run actually two mirage plus 21 and i hit the rev limiter at 5100 at 67 mph .
And he run 38 mph at 3000trs
Next step i will try 2 standard mirage 23 and i will see
Any idea to give me a hand???
Frank
Frankscarab is offline
Old 05-23-2006 | 05:14 PM
throttleup's Avatar
Default Re: What's the diff between standard mirage vs mirage plus
The Mirage Plus propellers have addidtional cup in the trailing edge which is not found in the older style Mirage. Many of the older boats perform well with the old style Mirage props but I think in your case the Mirage Plus will perform better. But there is no better way to find out than to try them for yourself. Safe Testing!
Julie
throttleup is offline
Old 05-23-2006 | 06:19 PM
onesickpantera's Avatar
Like Julie said the M+ has more cup and more progressive pitch. The M+ provides more bow lift and works better on boats that need the lift. The M+ will also have 100-200 less rpm due to the cup.
If your boat has good natural bow lift the standard Mirage may work well. Like Julie said you don't know until you try it on your boat. My Pantera likes the standard Mirage better.
onesickpantera is offline
Old 05-23-2006 | 10:05 PM
hunster's Avatar
Originally Posted by Frankscarab
I everyone
Frank
My bud repowered his 96 w/350 mag mpi and bravo's. runs mirage plus 23 's. Runs right at 5000 rpm. I have a 94 with carb mags and alphas, run the stock laser 2 23 pitch.
hunster is offline
Old 05-23-2006 | 11:20 PM
Thanks everyone
I will try that next week-end , and i let you know
Frank
Old 05-24-2006 | 11:51 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: What's the diff between standard mirage vs mirage plus
The Plus series also has a different hub bore depth and uses the PVS system.
[email protected]
bbladesprops is offline
Westcoast
Prop Talk
1
02-03-2007 11:54 PM
Formula311-SR1
Prop Talk
6
08-26-2005 02:16 PM
Bo Knows
1
03-11-2002 11:15 PM
BAD-HABIT
02-07-2002 07:12 AM
