Blower recommendation for 700 hp >
Old 05-25-2006 | 01:57 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default Blower recommendation for 700 hp
well been toying with the Idea of uping my 500 hps they right now have been dynoed at 565 hp was wondering what you guys would recommend for a blower carb package to get me to 700. I know I need other bottom end and piston cam work but just want to research the blower carb first
klaw is offline
Old 05-25-2006 | 03:01 PM
jryan26's Avatar
Default Re: Blower recommendation for 700 hp
klaw
what got them to 565? Did you up the compression? From what I understand, they have forged pistons anyway. Im putting prochargers on my 500s and hoping for at least 700. I would think that by putting M3s on them you would be there easily. PM Cigdaze. He has a nice low hour set for sale.
jryan26 is offline
Old 05-25-2006 | 03:11 PM
BDS 875, 2 750 cfm's?? Hows that for a start?
ActiveFun is offline
Old 05-26-2006 | 07:48 AM
jdnca1's Avatar
8-71's and 825 Demon blower carbs....Probably make 700 at 3-4# of boost. Cheap and easy to tune. I would leave the bottom end alone and you really don't need a cam change if you're only looking for an honest 700HP.
jdnca1 is offline
Old 05-26-2006 | 09:28 AM
Von Bongo's Avatar
Chief got 700 out of mine with Blower Shop 250's.
When we completely rebuilt them they made 680 at 5500 and we were conservative with the set up. A bigger blower spins slower and less heat but I wanted to keep everything as low profile as I could.
Von Bongo is offline
Old 05-26-2006 | 03:38 PM
birdog's Avatar
My choice !....I made 650 hp with 8-71s..750 Hollys & 4 lbs boost. Mild cams {468ci}...You will have a little more Comp. Better carbs, more cubes.
birdog is offline
Old 05-26-2006 | 10:29 PM
Why only 700 HP? That's a great engine to supercharge; with more boost and an intercooler 800 HP is easy . Lowering compression and a bigger cam are not necessary. Nickerson single blowthrough carb needs practically no tuning, just pay attention to the fuel supply system and ignition system.
Attached Thumbnails Blower recommendation for 700 hp-supercooler1.jpg   Blower recommendation for 700 hp-540-bulldog.jpg
tomcat is offline
Chuck
10-19-2006 01:04 PM
Buddy OO
10-01-2006 07:34 AM
WETTE VETTE
8
06-18-2005 12:33 PM
BadDog
34
02-18-2003 07:27 PM
