Livorsi Clamp On Trim Switch >
Old 05-26-2006 | 08:05 AM
Default Livorsi Clamp On Trim Switch
I need some advise.
I Have Livorsi Standard single controls and I purchased the clamp on single trim switch. Their does not seem to be enough room to run the wires through the throttle without it catching on something and wearing the sheathing. Any ideas or suggestions on where to run the wires?
Thanks,
RazorsEdge is offline
Old 05-26-2006 | 08:41 AM
Wobble's Avatar
SORE MEMBER
Default Re: Livorsi Clamp On Trim Switch
Originally Posted by RazorsEdge
I need some advise.
Thanks,
mine run down the back of the lever and then around to the leading edge where it goes though the console, i used the smallest tie wraps (color matched). Underneath I left some slack for the lever to move and tie-wrapped it so that it formed a small half loop. Just check it for a while to make sure it stays where you put it.
Wobble is offline
FASTTIMES
Wanted
3
04-05-2008 09:43 AM
Sydwayz
07-05-2007 09:40 PM
Longblockbenny
1
03-12-2007 05:50 PM
Johno
1
04-07-2005 08:26 PM
buck183
17
03-07-2002 05:26 PM
