need your advice tonight (saturday) on Drives
Ran my new 89 F35-7 for the first time today. If I want to go forward, I have to shift lever toward the back of the boat and shift towards the front for reverse. I run TRS with transmissin by the way. I heard if the transmission rubs reverse at high speed such like going forward, I could burn up the transmissin... What do I do? Boat ran well but do I switch props ? How can I tell if they are running in the right direction?
Originally Posted by flash32118
Props On Backwards!!!
YUP.........SWAP THE PROPS
This is assuming that no body mixed up the the transmissons or messed with the shifters
Doesnt get easier then That
"NEXT !!! "
Originally Posted by Fountain38SC
Guys give him a break, he's from Canada, they ofter get things reversed.
hey its all good, I understant such a short boating season doesnt make for much time on the water, gotta get it while you can
Make sure transmission lever going forward towards engine.
If the rotation of the trans is correct the L H drive should turn in the same direction as the engine. You will burn up the clutch
packs running in reverse.
