Halon system and other safety ??s
So I bought a Baja 342 with 502's. I am moving up from a 22' open bow so this will be nice.
Question about the halon system that is in the engine compartment. Does this have to be checked and if so how? Is this a CG thing that will get me a nice ticket if it isn't done correct? Also any other things that are different in the bigger boat from the 22 footer? How about a requirment for flares? I took a boating course a long time ago so I am going to sign up for a refresher.
I am in Virginia if it matters
Fixed/Auto systems can be an approved device. Depending on system and installation.
Here is a link to a informative interactive checklist.
USCG safety checklist
Annual Inspection
External examination, checking for dents, corrosion etc..
Leak detection
Weight inspection
Hose/Nozzle blockage
Ensure safety pins and tamper seals are intact
Issuance of Maintenance Release
Six Year Maintenance
External examination (as above)
Recovery of Halon
Internal shell examination
Lubrication of O-rings and valve stem
Application of "verification of service" collar
Re-fill of appropriate quantity of agent
Apply new tamper seals
Leak detection
12 Year Hydrostatic Test
Recovery of Halon
Pressure test of shell (integrity)
Replacement/Lubrication of O-rings and Valve stem
Service Collar
Refill of agent
Tamper seals
Leak detection
Maintenance release
Leak detection
Weight inspection
Recovery of Halon
Leak detection
Recovery of Halon
Service Collar
Refill of agent
Tamper seals
Leak detection
Maintenance release
So it sounds like I need to find a shop to do this.
Originally Posted by Pantera1
Annual Inspection
Leak detection
Weight inspection
Recovery of Halon
Leak detection
Recovery of Halon
Service Collar
Refill of agent
Tamper seals
Leak detection
Maintenance release
Leak detection
Weight inspection
Recovery of Halon
Leak detection
Recovery of Halon
Service Collar
Refill of agent
Tamper seals
Leak detection
Maintenance release
Well those are the recomended methods for service of the cylinder.. Im sure any place that recertifies fire extinguishers etc could check it for ya.
I know theres a big one here in the Northeast
Is this something that I need to carry around documentation for in the event that I get pulled over for a safety inspection? Or is having this system just nice to have in the boat and the CG doesn't want to look at it?
The best thing to do is to carry enough handheld units that the automatic system is not necessary for inspection. It is cheaper to buy new hand held units than to have them inspected.
Still not a bad idea to keep the auto system in operational order. I would much rather use the Halon system than dry chemical any day.
