View Poll Results: Denali or SLE1500 crew
Denali
70.00%
1500 Crew SLE
30.00%
Voters: 10. You may not vote on this poll
wHICH ONE BOTH VERY NICE.
Old 05-30-2006 | 04:05 PM
TeamSaris's Avatar
Driver-441
Racer
Default wHICH ONE BOTH VERY NICE.
Whick one would you guys want? Which one tows better?
Built them Denali 39k 1500 37k not much difference.
TeamSaris is offline
Old 05-30-2006 | 08:09 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: wHICH ONE BOTH VERY NICE.
ttt
Old 05-30-2006 | 08:29 PM
H20 Toie's Avatar
Neither are a very good tow vechile unless you are towing something real light
H20 Toie is offline
Old 05-30-2006 | 09:57 PM
UNSANE's Avatar
I looked up their specs and the Denali maxes out around 8000 and depending on the engine in the 1500, you could be 7000 to 10,000 for a tow rating. If you're committed to buying a GMC, the truck with the longer wheel base would be a better tow vehicle if you're going to be close to the max rating.
UNSANE is offline
Old 05-31-2006 | 07:31 AM
Wobble's Avatar
SORE MEMBER
Is this the Denali pickup?
Wobble is offline
Old 05-31-2006 | 10:53 AM
candyman35's Avatar
37k for a 1500? Find another dealer. You could get a 2500HD with a diesel for a little more and be able to pull anything.
Dan
candyman35 is offline
Old 05-31-2006 | 11:17 AM
Tantrum's Avatar
Either should pull the mini hawk just fine.
And the ladies will dig the big back seat in the Denali
Tantrum is offline
Old 05-31-2006 | 09:48 PM
tblrklakemo's Avatar
SeaRay Sundancer
the denali has the LQ4 6.0 under the hood, also available in the 1500HD and 2500's. It makes 325horse in the denali and 300horse in the PU trucks. 360 ftlbs of torque in both applications. The regular 1500 has a 4.8 or a 5.3, the latter having 285 horse. The denali doesnt have a low range T-case, so that might be an issue for pulling heavy boats out of water on steep ramps but it is AWD. The transmission is going to be your week link. Both have the 4l65, so you might want to get the truck if it has 4.10 gears, or put those gears in the denali. If you need a low range t-case, well, the truck is the way to go.
tblrklakemo is offline
Old 06-01-2006 | 02:07 PM
TeamSaris's Avatar
Driver-441
Racer
Dan
thats msrp
Old 06-01-2006 | 07:21 PM
candyman35's Avatar
Originally Posted by fast fun 2
thats msrp
That sounds better. How much weight are you planning to tow? Are you thinking about upgrading in the next few years?
My vote would be for the Denali if it meets your requirements. If you go with a Pickup spend a few extra dollars and get the 2500. Overkill is a good thing.
Dan
