Need PN for 30 PSI block bypass >
Old 05-31-2006 | 05:59 PM
Default Need PN for 30 PSI block bypass
I think my computer has been drinking. It seems to have lost the PN and source for the 30 PSI bypass valve for a 502. Anyone know where to get one?
Thanks,
Tim T.
BadDog is offline
Old 05-31-2006 | 06:07 PM
Default Re: Need PN for 30 PSI block bypass
I should add that this is a Gen IV. Engine builder says they cannot be re-installed. He had to remove it to clean engine after a rod bearing problem. Do I only need one? I recall an article about an 11 PSI and a 30 PSI, one for filter and one for cooler.
BadDog is offline
Old 05-31-2006 | 08:27 PM
SB
Article and part # is for the Gen V and VI since they are in oil filter pad, not the oil filter adapter like the Mark IV's.
Here's Scoggin Dickey's article:
http://www.sdpc2000.com/faq/kbhowto.asp?mt_sc=1
SB is offline
blue thunder
8
01-15-2004 06:29 PM
RickR
1
01-03-2004 09:13 PM
Mad Hatter
08-10-2003 11:55 PM
horizontalboggi
5
05-12-2003 05:14 PM
THEJOKER
09-13-2002 02:41 PM
