Water Pressure Gauge Sender?? >
Old 06-02-2006 | 05:33 PM
Default Water Pressure Gauge Sender??
Where does the sender go? There is a spare plug in the intake, opposite the temp sender. Will this work?
Stock Bravo cooling system
Shah Mat is offline
Old 06-02-2006 | 06:13 PM
Default Re: Water Pressure Gauge Sender??
Thanks, the block drain will work fine.
Next question.... Can I put an normally closed pressure switch in the other side to turn on the alarm/buzzer? That way if I lose water pressure for some reason it will alert me before it gets hot.
Shah Mat is offline
Old 06-02-2006 | 08:36 PM
MOP
Lightbulb Re: Water Pressure Gauge Sender??
You started off right use the intake manifold cross over not the block drains they will collect crude and rust that will plug it up. The switch idea is not bad but you should see the pressure on the gauge at low speed, at higher speeds the drive or transom pickup usually supplies more water then the system can use. Many guys that that do the higher speed have trouble with to much pressure. If a pump fails at speed you may not know it until you slow down, I can not tell you how many times I had a customers come in saying I ran X miles no prob then it over heated just as they came in.
Phil
MOP is offline
East Coast B
21
01-27-2006 08:38 AM
ratman
4
08-02-2005 06:40 AM
Danny_Ocean
4
04-05-2004 10:47 PM
Waterfoul
12
06-16-2003 06:47 PM
Waterfoul
06-15-2003 08:18 PM
