Spinning Props Inward Or Outward >
Old 06-03-2006 | 07:34 AM
jeff32's Avatar
Default Spinning Props Inward Or Outward
I just can't recall what was the affect on the boat to spin props inward or outward... Can you guys tell me?
jeff32 is offline
Old 06-03-2006 | 08:06 AM
Biggus's Avatar
Default Re: Spinning Props Inward Or Outward
On my old straight bottom Top Gun, I spin them in for more bow lift.
Attached Thumbnails Spinning Props Inward Or Outward-2005-sebago-lake-poker-run-215-large-.jpg
Biggus is offline
Old 06-03-2006 | 08:19 AM
jeff32's Avatar
I'd be curious to spin them out cause I think I'm running with the bow too high...
Nice picture by the way!
jeff32 is offline
Old 06-03-2006 | 08:23 AM
Shanghied Again's Avatar
Registered User
Depending on your boat, On some step bottoms you spin the props out for more control keeps the nose down, Most deep Vs spin in for bow lift and better speed.
Shanghied Again is offline
Old 06-03-2006 | 09:13 AM
RedDog382's Avatar
Turning bravo's in on a 382 Fastech. No ill handling at speed. Lifts the bow a little. Takes more finessing around the dock and windy conditions.
RedDog382 is offline
Old 06-03-2006 | 09:21 AM
Smitty's Avatar
As RedDog said in for bow lift and out for easy maneuvering at the docks.
Smitty is offline
Old 06-03-2006 | 12:10 PM
Rebel_Heart's Avatar
I spin them in on my single step 35 Fountain, however I do sacrifice control, backing and around the docks.
Rebel_Heart is offline
Old 06-03-2006 | 12:51 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Each hull design reacts differently. My 32 Sunsation for instance reacts no different in or out other than loss of dock handling. So they spin out. Type props impacts the results too.
Reckless32 is offline
Old 06-03-2006 | 01:56 PM
Hydrocruiser's Avatar
Arrow Re: Spinning Props Inward Or Outward
I found outward spin with cupped props was best for me.
-The props lifted the back-end out and up faster and kept the bow up just enough to give optimum speed and ride comfort. So planing was faster.The tabs could get the bow up more if needed.
-Spinning inward tends to glue the back end down more so the only benefit I see is faster turns but a bit of speed is scrubbed. Tabs seem less responsive.
-Handling with outward spin is a breeze when docking.
Hydrocruiser is offline
Old 06-03-2006 | 06:42 PM
GLH's Avatar
GLH
Jeff on TRS you have to switch the lower units to try that I think.
Docking sucks if your spinning in.
GLH is offline
