thunder bolt  modules >
Old 06-04-2006 | 01:34 PM
Default thunder bolt modules
I am reloacting them on the engine. I knew that the 2nd module was a spare. As I inspected them further I discovered that they are different. One module is P#4E26A V8-HP (not used) and the other one I was currently using P#6A05A V6-14.
What gives....? I wonder if it is some timing issue (retard while starting or high rpm retard?? This seems odd to me.
tomcei is offline
Old 06-04-2006 | 02:43 PM
Default Re: thunder bolt modules
2nd module Is that a spare and no wires are hooked to it?
The V6 14 is 14 total degrees advance. Used alot in blower applications.
1BIGJIM is offline
Old 06-05-2006 | 07:45 AM
vandeano's Avatar
There is a V-6 module new on e-bay for $20.00
vandeano is offline
Old 06-05-2006 | 06:18 PM
The V-6 module will give you a 14* advance when used on a V-6 engine. When used on a V-8 it will give you much less. (8 to 10 degrees); and yes, they are popular on blower blower motors and others running a lower basic compression ratio that allows starting at an initial high timing setting. The V-8 HP is probably a better choice for a naturally aspirated "spiced-up" V-8 with a compression ratio of anything over 9.5:1 or so. --- Jer
jpclear is offline
Old 06-05-2006 | 08:53 PM
thanks
tomcei is offline
Old 06-29-2006 | 09:03 PM
Leathl_WS6's Avatar
Would you consider selling the V6 module. I am in need of one.
Thanks Rob
Leathl_WS6 is offline
tomcei
9
06-05-2006 10:27 AM
carney
Fountain
2
10-14-2005 06:55 PM
Sates
2
04-13-2005 01:18 PM
convincor
4
05-12-2003 06:01 PM
dyno
3
01-17-2002 07:13 PM
