Outdrive Maintenance? >
Old 06-05-2006 | 03:06 PM
Default Outdrive Maintenance?
Ok fellas (and ladies), Now that I have pulled my outdrive for the first time in preparation for placing and aligning my new 502. What should I do to accomplish responsible maintenance? Do I need to replace that rubber gasket for the cold water pickup(Where I recently found pieces of my detonated impeller)? What about those little O rings on the drive shaft? Do I need to replace those? I plan to grease the U joint and drive shaft before I bolt her all back up…. What kind I grease should I use?
Post up your maintenance procedures when your pull your outdrive!!
Longrange4u is offline
Old 06-05-2006 | 04:16 PM
GOODT's Avatar
Default Re: Outdrive Maintenance?
drive shaft...... merc spine grease is reconended but any good marine grade will do
ujoints.... I use merc 2-4-c but again any good marine grade grease will do
it is recomended to replace the o rings including the water pick up o ring (yes I know its not round but they still call it an O-ring) when servicing the drive but not always nessisary
GOODT is offline
Old 06-06-2006 | 01:41 AM
Just found a great site for this...
http://www.marinemechanic.com/site/page79.html
Talks about all maint and engine alignment.
Old 06-06-2006 | 06:50 AM
vandeano's Avatar
Great site. So much helpful info
vandeano is offline
Old 06-06-2006 | 11:36 AM
J-Bonz's Avatar
For the u-joints, why use 2-4-c over the gimbal & ujoint grease? Not started anything, just curious on your opinion.
Thanks,
Jr.
J-Bonz is offline
Old 06-06-2006 | 04:03 PM
Joe's Avatar
Joe
Offshore Cowboy
Quit calling us "ladies"!!! That's the first thing.
(haha)
Joe is offline
Old 06-06-2006 | 04:50 PM
GOODT's Avatar
Thanks,
Jr.
2-4-C is an all around general purpose grease that has teflon and thats what I keep in my grease gun if I carried all the spec purpose greases id have to carry about 20 grease guns with me 2-4-c is a recomended grease for ujoints and gimbel brg along with trailer bearings ect
GOODT is offline
Old 06-07-2006 | 06:45 AM
J-Bonz's Avatar
Carring 20 grease guns is alot,
All you need are 2
"2-4-c" and "gimbal and u joint grease"
What do you think about the hole idea of not using teflon base lubricants with roller bearings?
Cant forget a tube of special 101, gotta love that stuff.
Jr.
J-Bonz is offline
Old 06-14-2006 | 01:36 AM
Ok fellas... anyone know of a gasket kit that has the o-rings and cold water pickup gasket in it?
Old 06-15-2006 | 05:25 PM
Beuller??? Beuller??
502SCS
Scarab
13
06-23-2008 09:50 AM
ninetym
Drives and Lower Units
1
10-22-2007 08:03 PM
fatdaddy
03-05-2005 08:33 AM
bcoffield
4
07-02-2004 11:08 AM
25 Eagle
11-20-2002 09:26 AM
