How to mount oil temp sender in pan? >
Old 06-06-2006 | 09:14 PM
Default How to mount oil temp sender in pan?
I am re-doing the oil system on my Gen VI and will not be using the remote filter. I have been looking at an oil temp sender that will be installed in the pan. It is 1/8 male npt. I have been unable to locate a fitting that will allow me to weld or fasten a 1/8 npt female into my pan. Any idea what the temp gauge is supposed to screw into?
http://www.racerpartswholesale.com/stewarn5.htm
http://www.racerpartswholesale.com/stewarn23.htm
BadDog is offline
Old 06-06-2006 | 09:20 PM
Elite Marine's Avatar
Default Re: How to mount oil temp sender in pan?
Mcmaster Carr or any pipe supply house should have fractional threadolets or half couplings - 1/4", 3/8" or 1/2" then you'd only need a reducing bushing to get to 1/8" NPT. The whole set up would be less than $ 10.00. But then it needs to be welded to the pan.
I used a SS bushing for mine, as it wasn't painted with the pan.
Elite Marine is offline
Old 06-06-2006 | 09:26 PM
MOP
Lightbulb Re: How to mount oil temp sender in pan?
You can go to a plumbing supply and pickup a steel not "cast" female 1/8 fitting, drill the the hole slightly larger then the senders tip and weld or braze the fitting onto the pan.
Phil
MOP is offline
Old 06-07-2006 | 05:40 AM
I poked around McMasterCarr.com What material should I get to be able to weld to the pan?
My choices are Black Forged Steel, 304 Stainless Steel, 304/304L Stainless Steel, 316 Stainless Steel, 316/316L Stainless Steel. This flange needs to be welded to the oil pan.
Where would a good spot to weld to the pan be?
BadDog is offline
Old 06-07-2006 | 06:20 AM
MOP
The pan is steel I would mate plain steel to plain steel, mounting is I feel should be pretty low. Mount it on the opposite side from the starter less chance of accidentally damaging it if you have to pull the starter.
Phil
MOP is offline
Dtile
7
02-18-2007 12:24 PM
klmken
3
06-01-2006 10:19 PM
stinger390
3
02-20-2006 01:08 PM
Danny_Ocean
4
04-05-2004 10:47 PM
convincor
6
07-05-2003 06:09 PM
