Any problems with Lightening Headers?
Official OSO boat whore
Guess it depends. They are no different from any other header. You can vary the point the water is dumped into the exhaust and how much. It also depends on your cam/displacement.
If you talk to Jahn or John (what ever his name is)at lightning he will tell you the normal wet lightning headers will revert water as easy as stock manifolds. My 502 and 540 were fine with them on with a 600 lift hyd roller w 228/236 at .050 at 700 rpm's idle with merlin iron heads,my new 540 with 600 lift hyd roller w/236/240 at .050 and afr cnc heads would STALL at idle from terrible water reversion with them.So there is a point depending on cam and cyl heads where they will not work unless you "dry"them up by adding water further back,Smitty
Great product and cannot be beat for the price. Jan is easy to work with and will build to suit if required. We've put them on dozens of boats with different configurations and had NO problems to date. In fact, we have them on our own boat.
The cam is the Comp "Extreme Marine" cam kit to retro fit a Gen V, it is a mild hydraulic roller. 540 lift, 260 duration... nothing extreme at all...
We installed them before with no problems. We also have them on Blown jets with no issues. They look & work great Just watch the cam size & dump the water late in the exhaust if you are going big on cam. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
