Bravo trim pump vs Volvo (SX) trim pump >
Old 06-09-2006 | 07:55 AM
CNC's Avatar
CNC
Default Bravo trim pump vs Volvo (SX) trim pump
Bravo trim pumps seem to always leak (and leak down) . The Volvos
are faster and seem to hold pressure better. Has any one ever swapped a Bravo Trim pump for a Volvo SX pump? Are the
pressures similar?
CNC is offline
Old 06-09-2006 | 08:20 PM
MOP
Default Re: Bravo trim pump vs Volvo (SX) trim pump
It should work fine the problem is finding fittings, I believe Merc still uses SAE not metric.
Phil
MOP is offline
Old 06-10-2006 | 07:36 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Phil
Ditto.. Although the later model ones may be interchangeable & work on the merc lines.. The other thig you will need to do if you swap them is mod your merc wire harness to work with the volvo pump. I believe those connectors are different. volvo is usually flat & merc is usually round.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
carter38
Drives and Lower Units
4
08-22-2007 10:43 AM
ratman
01-26-2006 07:48 PM
427 larry
9
08-22-2005 10:10 AM
SeaWeasel
2
07-21-2005 04:29 PM
Rambunctious
04-22-2003 06:37 AM
