Flush Fitting for Merc 502 Mag EFI
Need advise!
Have a Baja 272 with a Merc 502 Mag EFI which will be slipped aboard a HydroHoist.
Since I cannot get to the Bravo-1 outdrive water intake to use a freshwater adaptor, is there a device, fitting or connector which can be installed inside the engine compartment to simply connect a water hose to flush the engine with?
yes there is something. Do a search using the following and read up. There is a lot of really great info on here about that.
John S.
Do-it-yourself flush kit installs?
http://www.offshoreonly.com/forums/s...h+kit+installs
John S.
