Superbabi's goal for 100+... >
Old 06-10-2006 | 04:45 PM
TeamSaris's Avatar
Driver-441
Racer
Default Superbabi's goal for 100+...
can be done in an sb...
http://www.offshoreonly.com/esvon/page-10682.html
TeamSaris is offline
Old 06-11-2006 | 04:59 AM
Superbabi's Avatar
Default Re: Superbabi's goal for 100+...
Johnny I was thinking Cat until I called up INSU. CO, I was told I could not be insured without prior Cat experince. Gonna have to do it in a " V " !!!!
Superbabi is offline
Old 06-11-2006 | 08:02 AM
Pat McPherson's Avatar
Gary,
If you want your babi to run 100mph you will need about 900HP, right?
Your 502 block can be rebuild with a stroker kit to make it a 540cube. Then bolt that Whipple back on with a larger inter-cooler and a pulley set to crank up the boost. If none cracks the code on the existing computer, you need a new ignition and ECU combo. The GM MEFI 4 is the system a lot of builders are using these days. 900HP is vary much within reach with a supercharged 540...
As for the out-drive, check out the B-max (Bravo Shop)...
It's only $$$$$$$$$$$$$$$$$$$$$$$$$$$$
Patrick
Pat McPherson is offline
Old 06-11-2006 | 08:07 AM
lightspeed's Avatar
Better Start Lookin For Another Boat ///////////////
lightspeed is offline
Old 06-11-2006 | 09:03 AM
Superbabi's Avatar
Yep, another Y2K, with the new bottom !!!!!!!!
Old 06-11-2006 | 09:06 AM
JD seems to be the mood to sir things up.
Patrick
Old 06-11-2006 | 09:08 AM
TeamSaris's Avatar
Driver-441
Racer
Originally Posted by Pat McPherson
Gary,
unless you use a merlin or dart block it will never last. GM rates there 502 for 750 tops!!
Old 06-11-2006 | 09:17 AM
Good point, the cast main caps will not hold up to 900HP.
What if you rework the block for steel mains with splade bolts?
Are we sure the 600 is not build on a bow-tie block?
If not, I guess a new short block is in order then...
More $$$$$$... That's OK we're spending Gary's money...
Patrick
Old 06-11-2006 | 10:41 AM
Superbabi's Avatar
Money I don't have...........................
Old 06-11-2006 | 03:59 PM
TeamSaris's Avatar
Driver-441
Racer
90% sure we have built a couple 800+ bowties stock block they are weak i would go merlin for safety...
FX10
Superboat
18
11-24-2005 11:21 AM
