wiped a cam lobe yeterday
any body got an idea why i wiped a cam after only 60 hours aon a motor, soft cam, running to fat thinned oil, ****ty oil pump, i dont get it.............540 na eagle rotating assem,dart iron heads,comp stud girdles,crower rollers good springs, i thought i did everything right.............
Could be axial cam drift, happened to me. The cam position is maintained only by the timing chain. If there is even a slight amount of chain slop, the cam can drift forward or rearward. When that happens, the angle of the lifter contact changes. This can cause the lifters to stop spinning on the cam lobes (yup, they spin). Once the lifters stop spinning, the lifter and the lobe will be wiped out almost immediately. However, this condition will usually effect more than one lobe/lifter. Are you sure you only wiped one?
There is a fix for this, they are called cam buttons. Its a little thrust bearing captured by the cam gear that is set up with maybe 10-15 thousands clearance to the front cover. As the cam migrates, the bearing touches the front cover and limits axial drift. These cam buttons are used in continuously high RPM applications (like boat engines).
Just a thought for you to consider.
Holy sh*t 'Bird! That was an outstanding post!
solid, comp cams i think i have crappy oil pressure, and when we fired the motor for the first time i had no oil pres.... I think thats when i damaged it, and low oil pressure damaged it over time.....short time i am changing everything tore down the motor today only needs mains and cam but i am going through all the bearings......Changing to jesel system and going with a blower 1071 fork it,,,,,
thanks for your help guys
i had a little timing chain slack it was a combination of things.........
Originally Posted by RaggedEdge
Lets not be calling him a $hit Bird.
He's an intelligent guy and knows a lot about "thrusting" as it relates to AXAials. Told me that if your AXAial drifts fore or back it causes alignment problems and can result in shaft damage. Did I explain that right Third Bird ?????
All I can say is...WELL DONE>>>BRAVO>>>BRAVO!!!!
How to I paste this into the other thread???
I was wondering if somebody'd catch that.
