how much hp and tq will a stock bw72c handle reliably? >
Old 06-11-2006 | 08:04 AM
ratman's Avatar
Default how much hp and tq will a stock bw72c handle reliably?
thx for any info, rm
ratman is offline
Old 06-11-2006 | 08:54 AM
jeff32's Avatar
Default Re: how much hp and tq will a stock bw72c handle reliably?
this answer won't help you at all, but, if you run your prop on the wrong drive, like it happen to me, then if you want to go forward you'll have to run on the reverse of your transmission. I know now for sure the 2 disc cluth of the reverse does not handle a lot of horsepower like the 7 forward disc clutch... I learned that through a couple dollars to spend to fix this problem... But I'm sure you already knew that...
jeff32 is offline
Old 06-11-2006 | 09:30 AM
JCPERF's Avatar
370HP
JCPERF is offline
Old 06-11-2006 | 09:49 AM
a 10-18-014 is rated for 595 ft lbs tourqe .
open87 is offline
Old 06-11-2006 | 10:02 AM
Scarab3DMC's Avatar
600 hp...
Scarab3DMC is offline
Old 06-11-2006 | 10:28 AM
stecz20's Avatar
id say about 975 hp... yeah thats it rm.....
stecz20 is offline
Old 06-11-2006 | 11:08 AM
Panther's Avatar
Frank's Marine Service
I ran 550 hp on 71C's for 5 years until they started slipping and switched over to some BAM's. No problems otherwise. I would think a 72C could handle a decent amount more.
Panther is offline
Old 06-11-2006 | 11:19 AM
DONZI's Avatar
Some more spec's.
http://www.marinegears.com/catalog/cat-bw-dr1.html
DONZI is offline
Old 06-11-2006 | 02:04 PM
ratman's Avatar
jeff how fast will your rig go backwards
ratman is offline
jeff32
07-16-2008 06:37 AM
HotCig35
16
02-25-2007 07:18 PM
Hot Boat
8
10-26-2006 07:52 PM
Donzi502
8
10-16-2006 01:24 AM
Audiofn
22
11-16-2004 06:19 PM
