Drive spacer results >
Old 06-11-2006 | 08:18 PM
Default Drive spacer results
Installed a 1.5" spacer and went for a ride today. Picked up 2 mph cruise, and only got .5 mph top end. However, my top speed today was with 3/4 tank of gas, compared to an almost empty tank prior.
Top speed today was 89 mph @ 5600 rpm
Handling was a little different, but still felt "stuck"to the water. I need some more seat time find trim sweet spots and compare rpm/speed numbers.
Pure Energy is offline
Old 06-11-2006 | 08:35 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: Drive spacer results
Nice!
TeamSaris is offline
Old 06-11-2006 | 08:42 PM
Titan's Avatar
Great job Kendall keep playing it. Isn't this stuff fun...
Titan is offline
Old 06-11-2006 | 08:57 PM
TeamSaris's Avatar
Driver-441
Racer
Only when its free!!
Old 06-11-2006 | 09:29 PM
Pat McPherson's Avatar
Cool! it sounds like you will soon be running over 90...
After you burn off some of that $3.50 per gallon gas anyway...
Hey K, will you be out at your summer house on June 24th?
It does not sound like Summer Superfest is going to happen down on the south shore that weekend. Maybe it's a good time to gather at Claudio's again...
Patrick
Pat McPherson is offline
Old 06-11-2006 | 10:11 PM
Little by little. Next I'll see about the prop, then a nose cone.
Pat, yes I'll be out the 24th. Always ready for a run!!!
Old 06-12-2006 | 09:18 AM
Stormrider's Avatar
JC Performance Engines
Kendall, how much hp/tq is your engine running?
Nice results btw.
Stormrider is offline
Old 06-12-2006 | 10:11 AM
Probably about 750 hp. I did not dyno after the Whipple install. I'd like to get 2 seasons out of the motor, then take it back to JC for an overhall.
Old 06-12-2006 | 10:44 AM
Stormrider's Avatar
Sounds like a good gameplan kendall.
How are you liking it compared to the old sonic?
Old 06-12-2006 | 11:10 AM
SUPERSTITIOUS's Avatar
How far below the bottom is your propshaft?
SUPERSTITIOUS is offline
