What oil to use? >
What oil to use?
What oil to use?
Old 06-13-2006 | 09:07 PM
dean51267's Avatar
Default What oil to use?
Okay guys, I read the "MARINE LUBRICATION" thread and got WAY lost.... now I still have the same question.... here goes...
Just rebuilt 454's, mild cam, heads, and exhaust, suposed to go on Dyno this week, I need to determine what oil and filter to use. Please, keep it simple for a simpleton.... THANKS!!
dean51267 is offline
Old 06-13-2006 | 09:11 PM
Chris288's Avatar
Default Re: What oil to use?
mobil 1 15-50, stock merc. amsoil, or wix filter, change @ 50 or so hours
Chris288 is offline
Old 06-13-2006 | 10:36 PM
RLW
Flat tappet cam?
If you're going to break in the cam, you better use a non-synthetic oil with an abundance of ZDDP. I'll let the experts chime in on the selection of choice.
RLW is offline
Old 06-13-2006 | 11:40 PM
articfriends's Avatar
If your clearences are middle of the road kendall gt-1 40wt with a bottle of gm eos for extra zddp. If your clearences are loose,kendall gt-1 50wt. If you boat in fairly cold water kendall gt-1 20-w50. Seems like a good performance oil thats reasonably priced,I use it in all my performance motor's. If you can afford it switch to a good brand name synthetic AFTER your sure motor is broken in. If your running a flat tappet cam use the 15-40 diesel oil hydro talks about for breakin. If you go on his oil thread there is a abundance of info,every one has there personal favorite though,Smitty
articfriends is offline
Old 06-14-2006 | 11:59 AM
fund razor's Avatar
Originally Posted by RLW
Flat tappet cam?
That's what I was thinking too.
Personally... I am a Mobil One filter/ dinosaur oil guy.
fund razor is offline
Old 06-14-2006 | 12:33 PM
Hmm, and both Crane and Comp Cams reccomend Rotella.
But then again all I've ever used was 40W Rotella.
Gary
Flat tappet cam?
rdoactive is offline
Old 06-14-2006 | 01:48 PM
GOODT's Avatar
the best oil to use in a new marine mtr is the merc 25-40 other then that stay away from multi grades use straight 30 or 40 wgt oil do not do not use 15 40 or sysnthetics for break in
keep in mind that most multi grades are made for cars turning 1500 rpms at 65 mph not turning 4000 rpms
GOODT is offline
Velocity Vector
0
04-03-2008 01:45 PM
jeff32
06-28-2006 08:48 AM
FlyFast
13
05-10-2004 11:39 PM
