353fastech prop ? >
353fastech prop ?
353fastech prop ?
Old 06-23-2006 | 05:38 PM
ericaull's Avatar
Default 353fastech prop ?
I have a 2006 353fastech w/496HO's ,Bravo1x drives,and factory installed 4 blade 28p props.....i have been told that 26p labbed maximus 5 blades will give me a better top end, and improved mid-range. I have seen 72mph@4600rpms, light chop,saltwater. Any thoughts from the more experianced would be appriciated. Thanx, ERIC
ericaull is offline
Old 06-23-2006 | 08:29 PM
Default Re: 353fastech prop ?
same boat more options 73.5 GPS full fuel, full gear, stock 26 Bravos.
this is at 5000 RPM I am propped right against the rev limiter. Laptop scan of port engine showed just last week 114 touches on the limiter for a total of 6 seconds in 158 hrs.
shows my rev limit being 4994 RPM.
28's had no midrange and I can keep the boat on plane at a far lower speed with less tab with the 26's
I'm interested in the Maximus too for the cruise efficiency.
Rippem is offline
Old 06-23-2006 | 10:20 PM
ericaull's Avatar
Rippem, Thanx for the input. I only have 15hrs on the boat. I am just curious about those Maximus props...At 44-4600 she is still pulling but I haven't let it go all the way yet. Did your boat come propped with the 26pitch blades? I think I should let mine loosen up a bit before I start "messin' with the props".
ericaull is offline
Old 06-23-2006 | 11:52 PM
No mine came with 28's but I felt it was piggish. The 26's are better performers overall as I run heavily loaded alot.
15 hours? It's ready for oil/filter changes and WOT!
Rippem is offline
Old 06-24-2006 | 08:30 AM
ericaull's Avatar
The Dealer told me 20hrs.
ericaull is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
ericaull
5
10-09-2006 08:48 PM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
ellen bidlingma
0
06-03-2002 06:45 PM
