Can a MercII trans be replaced with a velvet drive trans??? >
Old 06-26-2006 | 03:50 PM
Wally's Avatar
Were doomed!
Default Can a MercII trans be replaced with a velvet drive trans???
I know they can....what i need to know is there a big size difference? Currently the cig in question has the mercII setup with TRS's.......wants ALOT more power and i'm thinking we need to change trannies to the Velvet drives.....question is how much of a difference between the two? Barely much room infront of engine to move it forward......
-Wally
Wally is offline
Old 06-26-2006 | 03:56 PM
CIG3's Avatar
Default Re: Can a MercII trans be replaced with a velvet drive trans???
Add about 4 inches. That is approx. how far you will need to move the engine forward.
I've run 400-450HP small blocks thru stock MercII's in race conditions no problem. You can add 1-2 forward clutch plaes to increase that to about 500HP.
CIG3 is offline
Old 06-26-2006 | 04:07 PM
Wally's Avatar
Were doomed!
Can they be built to handle 650hp???
-Wally
Wally is offline
Old 06-26-2006 | 10:29 PM
cuda's Avatar
I think so. I had mine rebuilt with the extra clutch plate, and the input shaft clearanced.
cuda is offline
Old 06-27-2006 | 07:39 AM
CIG3's Avatar
I think you would be ok as long as you took good care of them. Adding an extra cool helps. More capacity of fluid and cooling ability.
CIG3 is offline
Old 06-27-2006 | 07:46 AM
Payton's Avatar
Charter Member #927
Wally, I think another weak link is the pump gear. My old boat was in that hp range and that is what broke.
Payton is offline
Old 06-27-2006 | 08:22 AM
Wally's Avatar
Were doomed!
Ok....so extra clutch plates and check out the pump gear/possibly make new stronger one if need be....cool! anything else anyone wants to add about weakness in this trans?
-Wally
Wally is offline
smdude
Drives and Lower Units
6
11-08-2007 02:04 PM
Zanie
15
04-28-2004 06:00 AM
hystat
2
05-27-2002 05:35 PM
GO4BROKE
04-28-2002 09:48 AM
kaamacat
16
02-27-2002 05:32 PM
