Moorse Controls >
Moorse Controls
Moorse Controls
Old 06-27-2006 | 09:15 AM
BY U BOY's Avatar
Default Moorse Controls
AFTER SWITCHING TO A HOLLEY 750 I NEED TO ADJUST MY THROTTLE. WOT NOW IS HALF THROTTLE. EVEN THOUGH IT IS AT WIDE OPEN I WOULD LIKE FOR MY THROTTLE TO GO ALL THE WAY FORWARD. CAN ANYONE HELP ME WITH THIS.
THANKS IN ADVANCE PATRICK.
BY U BOY is offline
Old 06-27-2006 | 10:57 AM
SB
Default Re: Moorse Controls
Is your cable hooked to the real big hole on the Holley's linkage arm or one of the smaller holes ?
If not on the big hole you should change to this and it will give you much more travel.
SB is offline
Old 06-27-2006 | 11:10 AM
BY U BOY's Avatar
It Is On The Top Big Hole.
BY U BOY is offline
Old 06-27-2006 | 11:27 AM
SB
Does you shifter have multiple connections for the cable ? If it does, then moving it to one with less 'throw' will give you further action.
Lastly - If shifter has a positive stop, I'd adjust this so your shifter will stop when carb is at WOT. If not, the carb linkage will wear (bend,etc) if that is stopping movement.
Sorry, hard to type thoughts.
SB is offline
Old 06-27-2006 | 11:37 AM
BY U BOY's Avatar
I Will Check This Weekend. Thanks For The Help.
BY U BOY is offline
yss
9
01-31-2018 09:03 PM
bsirk
Detailing, Painting, & Fiberglass
13
04-18-2007 09:09 AM
grand lake
1
06-22-2005 12:53 PM
JIMB
0
06-20-2005 10:33 AM
rchevelle71
2
04-20-2004 09:13 AM
